Pro 3
Pro 4
I've gone to settings/ low light/ and toggled spotlight off. It still comes on with motion. Any way to disable spotlight on motion?
If the spotlight is turned off there, then it shouldn't be coming on when motion is detected.
You could try removing/reinserting the battery, and see if that resolves it. The other common work-around is to do a reset of the camera. https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
That didn't work.
