I want to switch off notifications for one camera without disabling motion sensing or recording, and without disabling notifications from the 2nd camera, but it seems to be an all-or-nothing setting.
The situation is that one camera is being used to provide security coverage of the driveway, and the other is (currently) being used to capture the activities of foster animals. I would like to be notified when someone approaches the house, but I don't need to know immediately every time Fluffy wants a drink of water.
Is there any way to selectively select which cameras can generate push notifications? I do want motion activated recordings from both cameras, so setting a deactivation schedule won't work for my purposes.
@EmJr wrote:
I have a shiny new VMS4240P Pro 3 kit.
If you look into the ARMED mode, you'll see that you can turn off the notifications there for specific cameras. You can set it up so that you still get the recordings. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
You can create custom modes that do this also, and build a schedule that uses different modes at different times.
