Pro 3 problems without the paid subscription. I've had it both ways!
  • 14 Replies
  • 2916 Views
Elkinde
Had Arlo pro with subscription for years. Now, Arlo pro 3 and free subscription ran out and now I've got problems. Not supposed to be necessary!
@Elkinde wrote:
Restarted everything and the base shows a solid blue light. Should be good! Nope. Arlo app shows everything is off line.
Did you try the full factory reset?  https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
14 REPLIES 14
dcfox1
What problems are you having? You will lose some options like cloud recording without a sub.
What options will I have when my Arlo trial ends?
Elkinde
VMS4240P-100NAS. Hub has to constantly be rebooted, "unrecognized format" message on local recording when trying to view, poor night pictures when I can view them(badly pixelated).
All this suggests a connection issue between the camera and the base.
Are you having any issues with live streaming?
Elkinde
Have not had any streaming issues from my phone.
Maybe try testing the USB drive?  Or use a different one if you have one handy.
You could also try directly accessing the drive on a PC, and see if you see the same problems as you get when using direct access to local storage.
Elkinde
Used 3 different USBs already. Unplugged everything a week ago and took it in to Best Buy and they told me all I could do is contact you. "Not Happy". Will plug everything back in this weekend and give it another try.
Not me - this is a user forum, and I don't work for Arlo.
Elkinde
Elkinde
So we're up and running again. Thanks! Can I get back to you if I run into these problems again?
Elkinde
So now some videos are viewable and others(majority) are "unrecognizable format".
JessicaP
Hi Elkinde,
Is this happening on both the web client on your computer and/or the Arlo app on your phone device? Could you show a screenshot where it's showing "unrecognizable format"?
Elkinde
On my phone, all I can view is live streaming. On my computer I was opening up the downloaded pictures with Windows Movies and TV, but now they are "unrecognizable".
Try using VLC and see if that works.  https://www.videolan.org/vlc/download-windows.html
  • 14 Replies
  • 2917 Views
