  • 10 Replies
  • 4557 Views
  • 6 In Conversation
FirstCup
Pro 3 file downloads or thumbnail views
I guess I do not understand what arlo is doing/has done to us. For years I’ve had a pro 2 subscription with 10 cameras on it and loved it. Could open up arlo and see everything in a few seconds at two separate properties or be notified if anything was going on. That is totally screwed up now. Thank you Arlo!
So now Arlo 3: I purchased a pro 3, three camera kit to see if I could do any better, wrong. I am in the second month of the three month trial subscription. About a week ago I can no longer view thumbnails in my library or the device list displays. It only shown a download arrow and I can not see what has triggered a recording until I download it I guess that is what is going on when I select it. What happened to my thumbnails view?
10 REPLIES 10
michaelkenward
Sensei Sensei
Sensei
Where are you looking for these thumbnails?
Just another user
Working fine here so must be a local issue. Start by rebooting the phone and reinstalling the app. Use the web client to see if it's happening there.
FirstCup
I view what I call "thumbnails" in the library view or device view of the app on my Iphone or Ipad where I could view a snapshot of what is in the video clip. (little pictures). A couple of weeks ago my system stopped generating these (little pictures) thumbnails. Now what shows are a wire frame and an arrow pointing down, which indicates a need to download. About the time this started I did install a 32GB USB thumbdrive in the VMB4540 to have an additional back up. Since I am in the middle of my 90 trial subscription I would assume nothing would have changed for me. I guess I have no understanding of how cloud storage and local usb storage work or don't work in this situation.  ??
michaelkenward
Sensei Sensei
Sensei
I asked because no thumbnails is a "feature" of direct storage access, using the local memory to view recordings.
What is Direct Storage Access and how do I use it?
The cloud should show thumbnails.
If you aren't telling the app to use the local memory – unlikely to happen by accident –  you should see thumbnails.
Just another user
FirstCup
Thank you, I think I see a little light through the fog. From the article you pointed me too I found the Direct Storage Access was enabled which seemed to be my problem, I unchecked it and my library shows my clips now. This must be something I did when I inserted the USB in the base and it is something I thought I needed to do.
If I go out on a limb and start thinking Direct Storage Access is for use when I might not have a subscription plan but want to download videos when I am on my locations network I can read my usb while it is in the base, or I could remove it from the base and view videos. And if I wanted to get files from a remote location I would use this Port Forwarding feature if I choose to do it that way. Thanks again.
michaelkenward
Sensei Sensei
Sensei
I am too much of a cheapskate to be suckered into the iPhone religion, so I have no idea how that works, but on the Android there is a choice at the top of the Library page.
Local storageLocal storage
That is the Library screen.
This is connected to the local wifi. Remote access if a completely different mess.
Just another user
ajmi
Cloud or not. A thumbnail should show.
chudak
I agree that thumbnails should show either in Cloud or via local USB drive.
It DOES NOT work for me.
When I disable Direct Access I see no USB files at all.
What do I do ?
dcfox1
What do I do ?
The USB does not have thumbnails at all just the download icon on phones. I view them on computer with the USB ejected and inserted and I use VCL player.
To record at all to local USB you need need Direct Access "enabled".
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
chudak
And USB can be shared !
(unless removed)
Very disappointing ...
  • 10 Replies
  • 4558 Views
  • 6 In Conversation
