Why is my video recording delayed by more than 10 minutes?
Are you referring to the time it takes for the video to arrive in library/feeds? Are you able to provide more details about the delay you're experiencing?
Yes, I have to look manually sometimes and when it does work there is a lap of 5-10 minutes in recording of videos.
The video will not arrive in the library/feed until the camera finishes recording. How long do you have your videos set to record on a trigger? The longer the recording time, the longer it will take to finish.
Thank you I will check I believe 3 minute
I wanted to thank you for replying to me. I have another question. I purchased a compatible charger for my cameras. For Arlo pro 3. It still says needs it??? What could I be doing wrong? Thank you for your help.
