Pro 3 Local Storage
  • 1 Reply
  • 918 Views
Retired_Member
Not applicable
Hub and 3 cameras. Only one camera is recording and its recording everything all the time.
If you turn that camera off, do you get recordings from the other two?
If you are getting excessive recordings in local storage and the camera is on battery, the only options you have are to:
  • reposition the camera
  • reduce the motion sensitivity
If the camera is on AC power, then you can also adjust the activity zone.  But if you are on battery, activity zones are processed in the Arlo Cloud, and all motion detection (in zone or not) is recorded in local storage.
  • 1 Reply
  • 918 Views
