Yes I have searched the communities. Nothing I found works.
I can log in on my laptop. I cannot log in on my phone.
I have change the password twice.
I have entered it manually on the phone.
I have used Lastpass to enter it.
When I press log in it loops back like it never registered that I entered anything.
Try turning the Wi-Fi off and then try again.
Can you try uninstalling the app and reinstalling it and then try logging in.
I have done that. Cleared cache. Forced stop. My apologies for not mentioning it. I was mad when I posted.
I forgot to thank you.
Is it perhaps the 2FA that is not working?
I changed the setting for verification to send SMS messages to my phone. I get a code, but when I put in on the phone I get an error, "An error has occurred. Please try again."
Apparently the site is refusing to accept the code it sent to me. I've tried multiple times.
Any more ideas?
That worked. Thank you. I would not have never figured that out.
I am glad that worked for you. Have a great day.
