Is it just me or is anyone else having trouble with login today? It was fine this morning but now I cant login on either my phone or my pc.
This issue is now resolved. Please let us know if you continue experiencing unexpected behavior when logging in.
Is not just you. I was going to ask the same thing. My Iphone still works. Sometimes get in and get the orange bar of death with different things a different times. one some long one starts with http problem. Other say right away it timed out. Now i cant get past log in screen.
Some customers are experiencing issues login into their Arlo Account, in certain cases after login they are not able to access the library or do live streaming. Arlo DevOps team is working on resolving this issue. For more updates please check: status.arlo.com.
I checked that earlier and it said staid status normal. glad ur working on it and it was not just me going crazy.
Is anyone seeing their base hub keep going offline?... Along with the orange bar on the app?
Not here i can see my hub and thats been fine.
Thanks for the replies. the status now is,
"Some systems are experiencing a major outage"
Mine must be one of them, lol.
My hub looks fine also.
weill, I guess I'm getting a lesson to not trust the reviews.
Many hundreds of dollars of junk sitting there with a Arlo symbol for sign in.
The web designers better get back to work and at minimum, open a page that says something is wrong.
Same issues as you... Won't even let me see if it's armed or not. Seems the reset button on the SmartHub has also become greyed out
It would be nice if the support site didn't say: System Status: Normal.
Clearly things are not normal right now.
Go to the bottom of this page and under support click system status it says major outage in most features. The status on support page shows normal ya but this link will show it.
Hi,
I had the same issue this morning too, but it's better now.
However, I just received an update on Arlo app for iOS and it seem slower than the previous version.
The cameras' status are slow to show current status, and the Mode tab are take longer to be available.
It take about 20 seconds to show the status.
things are working again,
But, again, there should be a first page alert that things are not well when something like today's incident occurs.
One should not have to go looking for status. Rather, it needs to be the first thing you see when you log in.
In my opinion.
