Lmarchant,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Remember, bundles with two or more cameras don't come with several mounts/camera. For example, with a two camera pack it is usually one screw on mounts and one magnetic mount.
Just another user
Yea my 3 cams set came with 2 mag mounts and 1 screw mount not sure why but seems its the way the do it.
Cheapskates. You spend getting on for $1000 for three cameras and they says a few cents.
Or they are being environmentally responsible and not supplying unnecessary junk.
Just another user
Heh, interesting. I just picked up 2 standalone Ultra's from Best Buy, and both factory sealed boxes are also missing mounts, but have the screw set.
