I’m not seeing any feeds and I don’t see Cloud/Local options at top of feed screen. Was working yesterday although there have been intermittent issues since release of new app. I’m on the latest version. Logged out and back in several times. Still getting ‘There are no events for this day.’ and not seeing yesterday’s events
Locally only, Android phone connected to local network. No VPN. Never had a problem until the app updated and tried to get me to pay for a monthly plan.
Local network, no VPN, Android
This is happening to me, too.
This happen to me too, any solution from Arlo now? Problem was found in Apr and it is May now 😕
Well, some problems don't get addressed for months, if at all.
Hi
I was informed there was a backend update. This should now be resolved.
Hi Shayne,
I'm not sure if this is directed at me or the other folks having issues. I downloaded the latest update. When I first go to Feed the Cloud/Local tabs don't show. After a bit they appear. I'm guessing it's some sort of performance issue and/or the order in which screen attributes are displayed. I am able to get to the data.
I'm on the latest iOS (18.4.1).
Still same problem here....
Thank you, I provided this information and I will let you know when I have more info.
Yes, still experiencing the symptoms, in a way. Feed now comes up sometimes, not always, since I reinstalled the app. But then the feed is hours or even almost a day behind, which is quite irritating...
My local feed started working again on May 19-20 but then stopped again. Has this not been solved yet?
@Huntster10 Can you describe the symptom?
6/5/25 and this is STILL a problem. This system has become essentially useless. Y'all gonna fix it?
After the auto update to App version 4.0 local access from "feed" is not worked ( the app kept circling then failed). After I request for the old version and complained many times. Then, some updated by Arlo without my knowledge, the feed is able to access my local storage but the previous day instead of today. I had to go to "Device" > "Smart Hub" > "Storage Setting" (where all the clips records from Local show up) Then either I can see the clips at this location or go back to "feed" and see all the recent recording.
The Software is still dissastered.
That method doesn't even work for me.
I get the error, "There was an error obtaining your library. Arlo team is working on this issue." and a "Try Again" link that never gives me anything other than the above message when I try it.
I have literally ZERO access to any recordings. I can't even tell if my system is saving any recordings at all.
The way to check that is to eject the storage in the app, remove it from the smarthub and connect it to a PC. Then browse for recordings on the PC.
@bearatebluebird Is this occurring with Android or iOS?
Mine is Android.
tried it. my pc recognizes that I've plugged something into USB, but no new storage drives appear for me to click on.
android
That suggests something is wrong with the drive. Have you tried to format it and use it in the PC?
I was hoping to avoid doing so in case there was data I could recover. but I just now reformatted. the drive still doesn't show up on the pc.
if I try a known good thumb drive (appears on the pc no problem), the 4540 base station still can't see anything.
guess I'll try doing a factory reset on it.
Looks like the factory reset on the base station did the trick. Was a serious pain in the a to do, since I had to climb a ladder and manually re-add all of my cameras by pushing the sync button on each camera. Then, of course, I had to redo all of the various settings.
SERIOUS pain. But at least my device is doing local recordings again. Irritating that they don't show up in the feed, though.
