I have Arlo Pro 3 cameras and a VMB4540 smart hub and am having an issue all of a sudden with viewing my local storage feed on my phone app (i dont not subscribe to any service but have always been able to watch my locally stored videos). I have had this issue before so i am fairly well versed in what needs to be done. Here is currently what I have in place
- properly formatter USB
- record locally enabled
- local storage enabled
- storage status = good
- view recordings enabled
- both smart hub and phone connect to same wifi network
So on my app, when i go to "feed" it gives me the option of cloud or local at top. When i click "local" it just says "No Events" - this is new all of a sudden because before it would load the locally stored videos for me to view.
Any ideas?
Have you checked the hub's settings under Storage Settings? Try ejecting and reinserting the drive as well as checking the drive on a computer to see if videos are actually being recorded. Try a different drive.
Thanks for the reply and suggestions!
Yes the storage setting is "good" status and when i eject the drive I can access the videos on my computer so they are definitely being recorded. Its just that i cannot view them on my app and I know I am on the same wifi network so not sure why they arent showing up there?
I have used different USB sticks as well. There is no error or anything, everything checks out as good and operating except the ability to view the locally stored videos on my app. This is frustrating!
Is a VPN in use? If so, disable it.
no VPN is used 😞
Seems to me that I remember sometimes needing to wait a bit for local recordings to show (a few seconds). If you wait or go to another tab and then back does it then work properly? Can you try a different phone?
Ya usually it takes a bit but the videos upload eventually...i have left it on for over 30 min and nothing, it doesnt even show that its thinking or looking for videos to download just says "no events" every time. I have tried on 3 different phones and same thing.
I really appreciate the attempts but i was hoping Arlo would chime in to see if they stopped supporting local videos on their app or this specific hub or if anyone else has this issue...or if anyone else is using local storage and its working?
That worked thank you!
