  • 2657 Views
Ejcotilla
Hello.  Anyone know how to determine what wifi network your Arlo system is connected to ?  I have a smart hub/4 cameras and wired doorbell  but can’t seem to get the doorbell to connect to the wifi. Thanks
The smarthub isn't connected to your wifi network, it is connected with ethernet.
Can you explain a bit more on where in the installation process the onboarding of the doorbell fails?
Also, are you trying to connect it to the smarthub, or are you trying to connect it to your home wifi?
Ejcotilla
Thanks for your reply.  The doorbell worked for a few years and just recently stopped. The bell still rings but the video does not.  When I tried to reset/add the doorbell it would not work/recognize  when trying to scan the QR code.
I am not sure if the doorbell was previously connected to the wifi or the hub.  I would want to connect it to which ever is the best option.  Any suggestions are much appreciated. Thanks
If you don't have a subscription, then it is best to connect it to the smarthub.
If you do have a subscription, then connecting it to the smarthub would enable local storage as well as cloud storage.  Signal strength is another consideration - if you have an android phone you can install one of several free wifi analyzer apps, and see how the Arlo (smarthub) wifi signal strength compares with your home wifi when you are near the doorbell.
Not uncommon, and very frustrating.  If you can disable 5 ghz wifi in your router, then try doing that.  Of course make sure your phone is connected to your home wifi.
Unfortunately in your case, there is also the possibility that the doorbell failed.
  • 2658 Views
