  • 6 Replies
  • 6568 Views
  • 2 Likes
  • 6 In Conversation
Patricknj973
Has anyone used double sided tape to attach the camera mount to siding?  If so did it work out OK, any tips? What specific double sided tape did you use?
Thank you!
6 REPLIES 6
Shaun1234
Virtuoso
Virtuoso
I wouldn't fancy securing a £250 camera with sticky tape!
dcfox1
Agree, Not sure if it will work on siding or how long it would last outside.
Silverfox335
have the magnet mounts on the outside stuck on with Nano tape got mine from ebay its very good
Destiny25
I want to mount a cam to the exterior of my townhouse, but property management doesn’t allow us to drill in to the exterior walls/roof. Any recommendations for mounting the camera without using screws?
If I was going to do so, I would use the 3M command strips... I have used them for the Pro cameras for a short bit.
BUT, also I would add a tether to a clip under siding just in case for long term.
As a PS... they do sell clips that are for siding with no holes ; ( search for more )
https://www.amazon.com/Siding-Hanging-Mailbox-Planter-Hanger/dp/B07JVNFKMM/ref=pd_bxgy_2/139-3008218...
Silverfox335
Try this Jeteven Reusable Nano Adhesive Tape, Multipurpose Transparent Double Sided No-Trace Removable Glue Tape,Washable Strong Gel Tape Gel Anti-Slip Adhesive Tape for Carpet,Photos Posters - 16.4ft(5M)
This is what I use your charging cable should help save it if it come’s off I stick it under the magnetic wall mount I stick it on the wall and leave for a day to grip on it works I have one out the back for about three month now
  • 6 Replies
  • 6569 Views
  • 2 Likes
  • 6 In Conversation
