Direct Access the USB Storage from App and Web Client Possible?
Hi. I inserted a fresh USB storage device (a SanDisk flash drive) into the Arlo Smart Hub base station for my Arlo Pro 3 cameras. I haven't been able to figure out how to access the videos stored on that flash drive directly through either my Arlo app on my phone or the Arlo web site client on my computer.
I saw on this Community Forum that as far back as November 2019 there was a promising sounding mention that "Arlo announced that they would support direct access to the storage from the app and web client by the end of 2019."
Did that actually happen? Or is there no way to view the videos on the flash drive other than to physically remove it from the SmartHub and insert it into a standalone computer?
In the App library select cloud at the top center and in the drop down select Hub instead of Cloud. You can't view local on the web site.
What is Direct Storage Access and how do I use it? (arlo.com)
Thank you. Will give it a try!
