Tigergirl2323,
Are you able to provide a screenshot of the error you're seeing?
Did you ever get an answer? I keep getting that message on my library setting.
Amatulla,
Content will not be saved to the cloud without a subscription to Arlo Secure. This is why the message you've attached is shown in the cloud library.
Under the library icon I keep getting a notification and my iPhone dings. It says "Cloud storage keeps all your clips secure...Learn More"
I can't find a way to get rid of this notification and I have no plans to subscribe to the cloud storage.
We have a second account with another set of security cameras under my husband's email address and he does not get this notification
Sounds like your trial subscription has ended. These cameras need a sub for cloud recordings. Check Settings, Subscription.
Then it may be that you have zones defined. Remove any zones (which require AC power and/or a subscription) to see if that helps.
