Am trying to connect my Arlo Pro 3 Smarthub base station VMB4540 with firmware 1.16.6.1 to Apple Homekit.
I have restarted the base station numerous times, reset it and removed and re-added it to the Arlo app.
The camera and the Arlo app work fine.
The `Arlo app has permission to access Home Data.
When I try to connect to HomeKit from the Arlo app, it walks me through the steps (BaseStation_xxx->Home->Room) but gets stuck on the "Requesting HomeKit info.." page. Support ticket has bee raised, but just checking on here in case there is an obvious solution.
Please help!
The fix for this issue has started rolling out. Please update your Arlo mobile app manually from the iOS store to version 3.5.1 and if you're still experiencing the issue, reach out to me in a private message with your e-mail address and I can send your system a HomeKit token reset.
Thank you,
TurnbullR,
Do you have a ticket number I can reference and request an update on this issue?
Thanks,
Hi, any update on this? It's really frustrating that after 48 hours, I have an expensive product which does not function as described. thanks
TurnbullR,
I do not have any new information on this issue at this time. The development team is actively investigating these reports and working on a solution. As soon as I have more information, I will provide an update.
Saying ts is not the only one with this problem.
Please help!
Any updates on the matter from Arlo?
The development team has to speed up!
I have Arlo cams and a wired videodoorbell, I bought a week ago a new base station (specially for Homekit) and it cost me a lot of money/ telephone calls/ working hours/ frustration and that still doesn't work with Homekit.
Thank you,
