@Umenss wrote:
Other day my hub stopped working and my cameras as well. I couldn’t get them running. I deleted cameras from my account. Done hard reset on them and reset my home Smart hub as well.
Do you mean the factory reset here?
If so, it might be worth trying again on one of the cameras.
@Umenss wrote:
Tried using support chat but it pages comes out as Page not found.
This is hard if no cameras are in the account - something Arlo really needs to fix. If you can get one camera onboarded again, then you can contact support using the app. If you have a subscription, then there will be a phone option.
The mods ( @JamesC or @ShayneS ) could also create a support case for you.
Umenss,
As StephenB mentions above, you'll need to factory reset the cameras before onboarding again. Also be sure the batteries are charged or plug the cameras in before onboarding.
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
@Umenss1986 wrote:
But I still can’t add them because they don’t pop out on add new device
Not sure what you mean by that, can you clarify?
@Umenss1986 wrote:
I held sync button on camera for 15 seconds till 3 amber lights flashed. So that’s mean I reset camera to factory settings.
Did you also remove the camera from the account?
