Arlo pro 3 Hub VMB4000
Hi,
Been using Arlo with 5 cameras for years. The other day my hub showed up as offline even though all lights are green and my router indicates its online. I tried powering on and off, to no avail, I reloaded the app and cleared cache, to no avail, I reset my router, to no avail. Tried accessing the cameras both online and thru the app, same results.
see attached photos.
Strangely, if I Restart my hub via the app it does cycle thru and restart, but then once again shows the hub as offline even though all 3 lights are green.
Thx
Hi
Are you still experiencing this issue?
