Can I create a rule that disables the spotlight on the pro3 cameras
  • 1 Reply
  • 744 Views
pent
I'd like to have a way to disable the spotlight on my pro3 cameras. Is there a way to do this via a rule? I'd like to have a "spotlight on" rule and a "spotlight off" rule.
If I can't do that - is there at least a way to manually stop the spotlight?
pent,
You can create custom modes to accomplish what you are describing.
Log in to your Arlo account and navigate to Mode > select your Arlo Floodlight (or Base Station/SmartHub if it's synced that way) > Add a Mode > follow the on screen prompts selecting the desired behaviors. This will allow you to create a mode that says when motion is detected, turn the floodlight on and a second mode that says when motion is detected just record video (do not select turn floodlight on). You can then select these modes as desired.
pent,
  • 1 Reply
  • 745 Views
