Camera not streaming
Go into devices and make sure that the camera is set to on.
The go to Mode - select the base to which the Pro 3 is connected and make sure that it's set to armed.
Then check the rule for the Pro 3 to make sure it's set to record if motion is detected.
The lack of live stream may be a clue, too. Try resetting the camera by removing and reinstalling the battery. It's possible you may need to remove the camera from Settings, My Devices and start fresh.
Is this during the original setup process? If so, use the camera reset procedure and try to connect again. If it shows in Settings, My Devices, remove it before using the reset procedure.
Any other suggestions
