pairing code
  • 2 Replies
  • 2049 Views
Christian66
How can I find the pairing code on VMB4540
There is no pairing code.
Can you explain what you are wanting to do?
The bases set up a wifi network for the cameras/arlo devices ONLY.  If you are trying to use the base as a router to connect to,  it will not work.  ( as mentioned , there is no pw to access the base unit for security )
  • 2 Replies
  • 2050 Views
