pairing code
@Christian66 wrote:
How can I find the pairing code on VMB4540
There is no pairing code.
Can you explain what you are wanting to do?
The bases set up a wifi network for the cameras/arlo devices ONLY. If you are trying to use the base as a router to connect to, it will not work. ( as mentioned , there is no pw to access the base unit for security )
