Re: Motion reported as SmartHub rather than camera name
- Email to a Friend
Hi,
Not sure why but we keep getting notifications advising that motion was detected on our base station.
Unable to find anything about this in the manual, in the Community discussions nor via searches on the internet.
Have a USB drive attached and video recordings are saved to it.
Unable to find a reason for any sort of motion with the base station.
Anyone experienced this?
How can I stop it occurring?
Thanks in advance for your help.
Cheers,
Mike
- Email to a Friend
A cloud fix has been released that resolves this issue. This fix is automatically applied and does not require any interaction with your Arlo system.
Thanks,
- Email to a Friend
Not sure why but I just started getting this message today June 23. For the first three months I never got this.
I know this does not help you but I just wanted you to know that you're not the only one getting them.
- Email to a Friend
mharps, K80Shooter
Are you able to provide a screenshot of this notification?
- Email to a Friend
I cleared my notifications, when I turn it back on and if I receive another I will update this post, Thanks JamesC
- Email to a Friend
Hi,
Attached is a screen capture of the notification received.
Cheers,
Mike
- Email to a Friend
Started getting the message "Motion detected on base station" along with the motion detected on the various cameras. what does that mean.
- Email to a Friend
May help a mod are you guys seeing this on Android or Iphone also. I have not seen it on my Iphone yet.
- Email to a Friend
Mine is on a android phone. Samsung Galaxy S7 Edge
- Email to a Friend
Same behaviour here with an older Samsung Android.
App version 2.17.1_28025
Hub VMB4540
Firmware 1.16.2.1_559
Just another user
- Email to a Friend
This issue has been escalated and is currently being investigated by the development team. I will post an update as soon as I have more information.
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
@Smolnar212 wrote:
Has this been resolved yet.
See above.
Watch this space.
Just another user
- Email to a Friend
- Email to a Friend
I have a curious issue ...
I have SmartHub with 3 Ultra cameras, for simplicity I will designate them 1,2 and 3
when there is motion detected on camera 1 it is reported as SmartHub
when there is motion detected on camera 2 it is reported as 2
when there is motion detected on camera 3 it is reported as 3
why is camera 1 name being reported as SmartHub?
i have edited camera 1 name - no help
I have reordered the cameras - no help
just a curious issue.
thanks
- Email to a Friend
There have been other threads on that recently. Its a bug. Not sure if it is just on Ultra cams only as my Pro3 's on the 4540 hub don't do that.
- Email to a Friend
- Email to a Friend
Arlo is on the case and promises to update the original discussion that started this saga.
Base Staion Motion Detected notifications - Arlo Community
Just another user
- Email to a Friend
Thanks for the link
- Email to a Friend
Add me to the list. I keep getting "Motion detected on Smarthub" and there are no corressponding recordings in the library to review.
- Email to a Friend
All of a sudden, my “side yard” camera, when detects, sends notifications saying detection on “base” whic is my base’s name, instead of “side yard” as supposed to and had always been. All other cameras behave normally. Just updated to June 25th update and it’s still doing it. Rename side yard camera to something else and it still says “base”. If it makes any difference, the side yard camera is the closest to the base.
Any ideas, thx
- Email to a Friend
@Amati5 As previously posted Arlo is aware of this bug and looking into it . It happens for some and not others so not sure what is going on.
- Email to a Friend
Oh, ok thx. I search briefly but didn’t find any threads on it
- Email to a Friend
For the last 5 days I've been getting the same notification ,motion detected on base station,happend after I updated arlo app,reset base ,re sync cams to base,still the same issue.
