Arlopro3 model VMC4040p What battery do I need?
  • 1 Reply
  • 2894 Views
Sophie81319
I have the Arlo 3 camera I bought it without a battery thinking my other battery would fit it.  What battery do I need and Do I need another charger My current system is Arlo 2
dcfox1
If you mean a Pro3 yes the battery and charger are different on newer models. The charger has a magnetic connection to the cam. I don't see the normal short charging cable that comes with it here but it has the battery and longer chargers. You can check other sites for the smaller cable.
Arlo Security Camera Accessories | Chargers, Mounts, Skins & More"
dcfox1
  • 1 Reply
  • 2895 Views
