I have the Arlo 3 camera I bought it without a battery thinking my other battery would fit it. What battery do I need and Do I need another charger My current system is Arlo 2
@Sophie81319 wrote:I have the Arlo 3 camera I bought it without a battery thinking my other battery would fit it. What battery do I need and Do I need another charger My current system is Arlo 2
If you mean a Pro3 yes the battery and charger are different on newer models. The charger has a magnetic connection to the cam. I don't see the normal short charging cable that comes with it here but it has the battery and longer chargers. You can check other sites for the smaller cable.
Arlo Security Camera Accessories | Chargers, Mounts, Skins & More"
