I have tried a few different set ups, but I’m trying to connect it to an Orbi mesh system.
All online articles are mainly talking about older hubs - the one with 3 led lights - so not much help.
Would love any advice
Thanks in advance
sounds like when the led goes blue, it is already connected ??
Chas_M,
Take a look here for definitions of LED behaviors on a SmartHub: What do the LEDs on my Arlo SmartHub or base station mean?
A solid blue LED indicates the SmartHub is connected to the internet.
Do you already have an Arlo account or are you setting up a brand new account? If you already have an account, start by making sure you're mobile device is connected to the same network as the SmartHub, then log in and tap " Add New Device" then select Base Station / SmartHub and follow the on screen instructions.
I have started a new account, and have followed the set up instructions to add a hub but it still can’t find it.
Chas_M,
Is the Arlo SmartHub connected to an Orbi satellite or the main Orbi router? If connected to a satellite, try connecting to the main router and see if you experience different results.
Yes it’s connected into the main Orbi. Is there any specific settings I need to have? It’s weird the light is blue (so connected to the internet) but it doesn’t want to
Just to be clear, I’m going into the new Arlo app, logging in, going to settings, going to New System Set Up, Going to Arlo Base Station. Doing the steps - the LED goes blue but it’s not discovering the Smart Hub. I’ve reset the hub several times. Still nothing.
Chas_M,
I will reach out to you in a private message to gather more information on this issue.
@Rookblue wrote:
I have new hub and account and can’t find the password for my hub
The hub does not have a password.
It operates via an online "My Arlo" account. Use this with a mobile app or your browser.
The wifi bit of the hub, if that is what you mean, is beyond your control. The hub talks to the cameras with wifi, but connection to the internet, and your local network, is via the wired LAN link between your router and the hub.
By the way, you have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
Just another user
@Marshview28 wrote:
I am having the same problem. Arlo Pro 3 directly connected to the modem.
What is this modem?
@Marshview28 wrote:
Flashes orange at first then goes solid blue. Fails to connect.
Solid blue = connected.
So what else is going on? What are you doing and where does it go wrong?
Just another user
@Marshview28 wrote:
I am using an Optimum Router. I am also using an Orbi mesh. I am connected directly into the router
It probably isn't relevant here, but unless the Orbi is in wireless access point mode that smells like two routers on the same network, which is not a good idea.
And the other questions? What are you doing and where does it go wrong?
Just another user
@michaelkenward wrote:It probably isn't relevant here, but unless the Orbi is in wireless access point mode that smells like two routers on the same network, which is not a good idea.
I think your point is very relevant.  If the Orbi is not connected to the router in Access Point (AP) mode and instead connected in Router mode (see here), then it creates a double NAT situation with two different networks.  Devices connected to the Orbi may not be able to see devices connected to the router.  That could make it difficult for the Arlo app (on a mobile device connected via wi-fi to Orbi) to discover a new Arlo base station (if connected directly to the router).
But the message said "I am connected directly into the router", not to the Orbi system. But as you say, is the wifi connected to the router or the Orbi?
However, without answers to the other questions, I am guessing. The hub seems to be connected to the Internet. But that is just the start of the process.
Just another user
Agreed. Arlo does handle double NAT - I do double-route with my Orbi in router mode behind behind my ISP router. But my Arlo base is connected to my Orbi's ethernet, not the ISP router - which works fine.
FWIW, there are often good reasons for double-routing, so it's not necessarily a "bad idea". In my case, I use OpenVPN. Orbi includes it in router mode, but not Wireless AP mode, and my ISP router doesn't have it at all. If I drop the ISP router, then I lose cable TV services. So double routing is the only way to get all the services I use.
Corey123019,
What is the LED behavior on your SmartHub? What error messages are you seeing within the app that indicate an issue?
My hub light is blue (connected to the internet) however the app says it cannot find any arlo devices.
I logged out of the app and tried to log back in (yes, on the same device I used previously) and I get an error message stating “We do not recognize this device.”
I have followed every step, over and over. No success yet.
Keebler25,
Is this a brand new SmartHub or has it been used previously? Have you tried factory resetting the SmartHub before trying to add it back to the account?
How can I reset my Arlo SmartHub or base station to the default values?
I am having the same problem on a VMB5000 that has worked for over a year. I think during a rain storm it might have lost power when trying to update the firmware. This has happened to two VMB5000s in less than a month.
Brian
KingTom,
What does the signal strength icon show for the cameras? If the signal is poor, this could be why you're experiencing issues.
JamesC,
Thank you for your response. The issue is that the Pro 3 smart hub is not recognised by the Arlo App. I have a Pro 2 base station and the Pro 3 cameras are currently connected to it.
Hi, I am having the same issue. Our system has been connected for about 3 weeks and I woke up to our Arlo Pro 3 system not working, even though the smart hub light is blue. I've tried resetting and troubleshooting the hub several times, reloading the app, and my iPhone is not finding the smarthub base. I'm totally confused! Any help??
Thanks,
Casey
