Arlo pro 3 keeps dropping offline
If I take the camera out of the housing and remove battery it works as soon as I put it in the housing it goes off line my internet has 200 mbps download and 20 mbps upload which Arlo say is what it requires I had the same issue with my pro 4 intermittently so I down graded to a pro 3 hoping it would resolve the issue I had a pro 2 in the same place and never had a issue once
Some punctuation would help so we could determine the process you're using. It's not clear at all as to the steps you're taking.
Ian_speeding,
If you had the same issue with a Pro 4 in that location, it would seem something at the location is causing an issue. Try moving the camera to a different location temporarily and test again to see if you still experience the same behavior.
