Can you access your cameras from 2 separate phones and if so how do you do it
Arlo only allows one login to the account at a time, so if you try to use the same account on both phones, the first phone will be logged out when the second phone logs in.
You can avoid this by setting up a second account for the other phone. Then share the cameras with that second account using the "friend" access feature.
- https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
- https://kb.arlo.com/1103229/What-privileges-do-my-friends-have-when-I-grant-them-access-rights-in-my...
FWIW, it usually works out better if you click on the "Create account" link in the invite on a PC. That will open your browser to my.arlo.com. From there, you can create the account - or if it already exists, just log in.
