Arlo pro 3 access your cameras from 2 separate phones
  • 1 Reply
  • 721 Views
Wozzy24
Can you access your cameras from 2 separate phones and if so how do you do it
Arlo only allows one login to the account at a time, so if you try to use the same account on both phones, the first phone will be logged out when the second phone logs in.
You can avoid this by setting up a second account for the other phone.  Then share the cameras with that second account using the "friend" access feature.
FWIW, it usually works out better if you click on the "Create account" link in the invite on a PC.  That will open your browser to my.arlo.com.  From there, you can create the account - or if it already exists, just log in.
  • 1 Reply
  • 722 Views
