  • 2312 Views
Macsak
Hi I bought arlo pro 3 last month and put in the charger for 5 hours but not charging. Would anyone help me please. Thanks. Regards. Mac
Macsak
Thanks guys. It was problem with charger adapter. Didn't fix it properly while charging. Now everything ok.
Are you sure you are using the supplied ac adapter to charge?  A normal usb one will not work.
If so, make sure the contact area is clean... I usu place the connector on a try to wiggle same
I've also had a couple of times where I *think* the connectors had to be wiped off to work. That was outdoors and after some period of usage, though. I also can't prove that that was the problem.
Macsak
  • 2313 Views
