System lost a camera connection and won’t reconnect. I deleted it and tried to reinstall but nothing works. This system seems to be very poorly made, hence an entire forum to deal with how bad they are.
SteveMcB1,
When you say you "deleted it and tried to reinstall" do you mean you removed your camera/SmartHub from the app?
If so, you will need to perform a factory reset on your SmartHub and go through initial setup again.
For more information on factory resetting, take a look here: How can I reset my Arlo SmartHub or base station to the default values?
