HomeKit Extra Accessories
Just purchased the Arlo Pro 3 camera from Costco. When I go in to add the system to HomeKit it keeps adding extra cameras that are titled “Motion Sensor”. It properly shows the camera and motion sensor I have connected, but it always includes extras with “no response” under a default room. I reset the base station and removed/added to HomeKit a couple of times with no success. Thoughts? I only setup one of the cameras, the other two cameras the kit came with are still in the box.
Just to reply to my own post here this is what I have discovered in the event it is helpful... even though I only had 1 of the 3 cameras connected or setup, for whatever reason HomeKit was showing all 3. Because when I added the second camera it filled in with one of the error items. I imagine when I add the fourth, all will show.
So if you get the 3 camera kit, attach all three cameras and update the entire kit and it should all work well. Hope this helps.
Thanks,
Galen
