HomeKit Extra Accessories
  • 1 Reply
  • 1181 Views
  • 1 In Conversation
ArloG007
Just purchased the Arlo Pro 3 camera from Costco. When I go in to add the system to HomeKit it keeps adding extra cameras that are titled “Motion Sensor”. It properly shows the camera and motion sensor I have connected, but it always includes extras with “no response” under a default room. I reset the base station and removed/added to HomeKit a couple of times with no success. Thoughts? I only setup one of the cameras, the other two cameras the kit came with are still in the box.
ArloG007
Just to reply to my own post here this is what I have discovered in the event it is helpful... even though I only had 1 of the 3 cameras connected or setup, for whatever reason HomeKit was showing all 3. Because when I added the second camera it filled in with one of the error items. I imagine when I add the fourth, all will show.
So if you get the 3 camera kit, attach all three cameras and update the entire kit and it should all work well. Hope this helps.
Thanks,
Galen
  • 1 Reply
  • 1181 Views
  • 1 In Conversation
