@Goosefudge wrote:
I have the same issue, now on my second base station having returned the first one and I still have this problem.
Base station shows as a connected device when i log into my router admin, but i cant connect / discover it from the app, and has the persistent flashing amber LED. ( tried different network cables, base station powerdown and resets.
Since it is showing up on the router, we can rule out any ethernet problem.
- Do you have any parental controls set up on the router? If you do, try disabling that.
- Maybe also try changing the DNS setting in the router to 8.8.8.8 (Google DNS) or 1.1.1.1 (Cloudflare)
- If you use DoT for DNS, try changing that back to ordinary DNS (If you don't understand this, then it doesn't apply to you).
Did you due a hard reset of the base ( hold in reset for ten secs till led flashes ) then attempt
I have not tried that TomMac - Thank you I will do that when I get home from work.
Very frustrating.
Hi StephenB
No parental controls, and ordinary DNS in use.
From other threads, there is a consensus that there is a firmware issue impacting Arlo Pro2/Pro3 for anyone in Singapore using Starhub ISP. This fits my profile.
Thanks for the advice though.
It worked! - I had to go in and disable 1.1.1.1 cloudfare app in order to be able to connect my base station/ hub.
I disabled it for the hour while I set up the hub and cameras and everything works great now - PHEW!
I was getting really annoyed
Thanks for the support!
