Verify that you have a working subscription and that the camera is included. That shouldn't have an issue with live viewing but certainly would for recording. ALso, try moving the camera closer to your router or base, depending on how you have it connected, to see if that helps.
I suggest trying the motion detection test, to make sure the camera's motion sensors are still working. https://www.arlo.com/pl_pl/support/faq/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-de...
Also see if you can make a manual recording when live streaming.
@BadTime32 wrote:
I did test but although flashes amber no notification or recording
Can you make a manual recording, and then see it in the library?
