Do I have to buy the Arlo 3 to add to my current 3 cameras or can I go with any model...ie Arlo 2, ultra,or pro. Can I also add Arlo doorbell to the Arlo Pro 3 system?
To be clear any generation camera will work with the pro 3 hub?
,bolind2
You are not limited to adding additional Arlo Pro 3 cameras. You can add any Arlo camera/device to your existing Arlo ecosystem.
If you mean the VMB4540 hub in your "footer", then I have Pro 2, Pro 3, and Ultra cameras connected.
Just another user
Thank you!
