Arlo Pro 3 Siren only on Camera?
I can't seem to find the answer to my question regarding the Arlo Pro 3 cameras siren. Does the Arlo Pro 3 siren only sound on the camera or can it sound on the base station or a phone?
The Pro 3 siren is on the camera.
But you can also get it to send alerts to a phone.
Some older hubs also have a siren, such as the original Pro 2 hub, but not the one that is bundled with the Pro 3 system.
Just another user
I bought the Arlo 3 'VMB4540r2' set in July, 2020. In my experience, it was a very bad idea to move a siren from the SmartHub (as it worked well on the previous models) to a camera only.
A few things to consider:
- When for any reasons a siren start sounding, it disclosures it's location, and thieves can destroy the camera right away, or in advance coming next time well aware of the camera's location
- Sound level of the alarm on a camera is not loud at all, in reality - really weak
- While I'm sleeping, I do not check any notifications. Accordingly, if a camera is sounding really weak and is located outside of my bedroom, I cannot hear the alarm, and this sort of new Arlo 3 "security enhancement" will bring criminals into my bedroom undetected
I'm looking for any solutions to make a siren louder and bring the siren back to SmartHub, or transfer a siren's sound from camera to any sounding device. I'm contacting Customer Support as well.
Meanwhile, G-d forbid, if criminals would robber my house undetected because of such Arlo's new "enhanced security"...
