Hello,
I have the Arlo Pro 3 Floodlight over the garage door. It detects and turns the light on, but after max. 12 seconds it turns it off again.
I have set it to 5 minutes, Constant.
Any idea what I can do? I had somebody fall because the light turned off. I don't want this to happen again.
Thank you.
@RolCin wrote:I have set it to 5 minutes, Constant.
The light is turning off when the motion recording stops. Try increasing the recording duration in the camera rule(s)
Hello Stephen,
I can test it out tonight, but you are right. I had the setting for ... "until motion stops". I will let you know. Thank you.
Thank you Stephen,
it helped and it solved the problem. Thanks again.
