How to disable blue flashing light on the camera?
  • 8 Replies
  • 4989 Views
Fishingsiao00
  • May i know how to disable the Blue flashing LED light on the camera?
It’s very disturbing especially at night when u are sleeping u are awake by the bright blue flashing light.
Any kind soul please help! 🙏🏻
8 REPLIES 8
Fishingsiao00,
You should find the charging LED toggle by navigating to settings for the desired camera > tap on the ">" icon next to the camera name > select Indicator LED > Battery Fully Charged toggle
More info here: https://kb.arlo.com/1200780/How-do-I-turn-my-Arlo-camera-s-Battery-Fully-Charged-LED-on-or-off
Fishingsiao00
Hi James,
I have already turn off the Camera LED but the flashing blue light still continue.
Anyway the power supply is 24/7 switch on. Does it matter?
Fishingsia00,
Take a look here for more information on LED behaviors: https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
Is the flashing constant or does it only happen intermittently?
Fishingsiao00
Hi JamesC,
I’m using Arlo Pro 3, it is fast flashing blue light for 1-2 seconds.
Only sometimes it happen.
Could it be due to the network connection? Sometimes my Wifi connection has intermittent issue.
Fishingsiao00,
A fast flashing blue LED indicates the camera is reconnecting to the network. If your network connection is interrupted, this would be the expected behavior when the connection is re-established.
Fishingsiao00
Hi JamesC,
Do you have any idea how to disable it? Or u have any good solutions?
One workaround is to put some black (heavy) tape over the LED.
Fishingsiao00
Hi StephenB,
Very Good idea. Thank u very much 😀
  • 8 Replies
  • 4990 Views
