  • 6 Replies
  • 1590 Views
KamilB
One day my camera just stopped working, it doesn't respond to anything, it doesn't charge, I can't reset it, it's completely disconnected from reality. Do you have any ideas?
@KamilB wrote:
Yes. Dosn't work.
Then the camera must have failed.  Arlo doesn't offer any repair options.  That said
  • if the camera is under warranty, you can get an RMA from support
  • Even if the camera is not under warranty, support might offer a discount on a replacement.
If you have a subscription, you could reach support using the support center in the app.
6 REPLIES 6
Do you have other Pro 3 cameras?  Or just the one?
KamilB
I have 4 cameras
@KamilB wrote:
I have 4 cameras
Did you try swapping the battery with one of the working cameras?
KamilB
Yes. Dosn't work.
@KamilB wrote:
Yes. Dosn't work.
KamilB
Thx!
  • 6 Replies
  • 1591 Views
