Arlo 3 Camera's, base station VMB4540r2
On or around 12/1/2020, my 2017 Chevy Colorado's remote wireless entry key FOB's stopped working. Both of them. I replaced batteries and screwed around with the car before figuring out it was only when I was parked in my own drive way. I suspected some kind of interference with some other source. I have an Arlo Pro 3 protecting my drive way and the cars. I found that if I remove the battery from that camera, my key FOB's work but not as they should. After removing all the batteries in my 4 camera's. I found that the FOB's work perfectly. This doesn't affect my other car's FOB which is a different model of car. Anyone else noticing issues with interference with other devices caused by Arlo camera's?
Arlo doesn't interfere with the fobs for my 2016 Cadillac ATS-V. Guess Chevy could use different frequencies but that doesn't seem likely.
It doesn't interfere with my 2016 Cadillac XTS or my 2008 Silverado.
