- English
- Floodlights
- Arlo Pro 3 Floodlight
- Re: is Arlo base compatible with Arlo Pro 3 floodl...
i have some older model arlo (example of model number: 4N716878FEDC3)
Can i but a Arlo Pro 3 floodlight camera and add it to this base station?
You are listing the serial number - not the same as the model number. Some Base station models include the VMB4000, VMB4500, VMB4540, VMB5000.
This guide should give you the answer: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
