  • 6 Replies
  • 2628 Views
RHTPA007
Has anyone had success with getting replacement mounting parts for this camera. Customer service tells me that if the mount is broken ...you have to buy a whole new camera.
I obviously can "rig" something....but thats not my goal.
6 REPLIES 6
What exactly is broken? You say the mount but that can be various things including the camera cover. If the cover is ok, you can use almost any outdoor camera mount which uses the standard 1/4"-20 thread which will screw right into the cover. The cover itself is available but also includes a battery.
I don't think that's the case with the floodlight. Are you certain you weren't thinking of the Pro 3?
It's been a while since I did anything with the floodlight mount so you may well be totally correct. In that case, the possible remedies are that case with battery, which does have the 1/4"-20 threaded mount or use the app to go to Settings, Support and select your camera. Scroll down to Contacts to see if official support can help and insist.
@JamesC , @ShayneS , @BrookeN can you help here?
AFAIK there is no "case with battery" that will fit the floodlight camera.   The XL upgrade kit doesn't list the floodlight as compatible; neither does the total security mount.
Unfortunately, I believe support already gave @RHTPA007 the correct answer here - the entire camera needs to be replaced.  Support might offer a discount.  Or as @RHTPA007  said above, he could attempt a DIY repair.
Interesting since the accessories for the floodlight shows the case with the XL battery. I suspect it would work but can't be sure.
@JamesC , @ShayneS , @BrookeN can you verify?
Likely because the floodlight uses the XL battery.  But neither the list below the title nor "View Compatible Devices"  include the floodlight.
@JamesC - I think the correct accessory link for the Floodlight is the XL battery (without the housing).
That page includes the Floodlight at the top, and also in "View Compatible Devices"
  • 6 Replies
  • 2629 Views
