- English
- Floodlights
- Arlo Pro 3 Floodlight
- I have changed wifi providers and since then a lot...
I have changed wifi providers and since then a lot of my cameras will not sync. Do not chime
Help
does not recognise QR code or chime since a wifi provider change
@Safeaschips wrote:
Help
Probably too late now, but the easiest path is to set up the new router to use the same network name and password that the old router used.
You could try that idea first. If it fails, try
- removing the camera from the account (if not done already)
- fully charging the camera
- do a hardware reset by removing the camera from the housing, holding down the button inside until the camera LED flashes amber (about 15 seconds)
- add the camera back
Were you able to reconnect the cameras as well as the chime?
