Not much information to go on there.
So, this is the iOS app. Have you tried it with the browser interface and https://my.arlo.com/?
Is it connected to a hub or to a wifi access point?
Can you see the camera and live stream from it?
Just another user
@sbrecruiter wrote:
....I tried to access via my Arlo site on Safari, Chrome, and FireFox browsers on my Iphone.
But can you actually get at my.arlo.com with a browser?
What happens when you try?
@sbrecruiter wrote:
“View cameras” button would not work.
Where is this “View cameras” button?
Just another user
Yes. I am able to access my.arlo.com on my iphone as well as my Surface Pro
On the Iphone version, it has a "View Cameras" tab. When I click that, nothing happens.
Using my desktop, I am able to see my device on my.arlo.com and live stream the floodlight cam. I can see my device on the Mode tab as well, but it is blank on the right side where there should be options to arm/disarm.
sbrecruiter,
Consider rebooting the floodlight by removing and reinserting the battery. Test again to see if you still experience the same behavior.
I removed the battery and reinstalled it. I'm still not seeing any options when I go to the "Mode" tab on the iphone app or desktop my.arlo.com website.
Ds41439,
Does the happen when using the web client? Is it intermittent on your iOS device or does it always happen?
JpMaxMan,
Try removing and resyncing your floodlight. Do you still experience the same issue?
A new firmware update for Arlo Pro 3 Floodlight was released since this issue was last reported. Check to make sure you have the latest firmware version available and test again to see if you still experience this issue.
Firmware Release notes: https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Pro-3-Floodlight-FB1001-1-080-23-2-29-b953...
