  • 5 Replies
  • 1212 Views
Svagere84
Hi ,my cameras stop working it's says offline and I can't connect them again.And before they missing some recordings aswell.
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support through the Arlo Mobile App by navigating to Settings/System/Support.
5 REPLIES 5
We need more info - all of it. To start with, are the batteries charged? Are you connecting to your WiFi or to a hub?
Svagere84
It's working now,but not recording everything,connected with WIFI,batteries charged,I need them recording everything,but they not recording,missing a lot recordings,not showing all the time what's going on
Disable Smart Notifications to see if that's the cause of "missing" videos.
Svagere84
Done,but still the same most of time there no recordings at all
ShayneS
  • 5 Replies
  • 1213 Views
