- English
- Floodlights
- Arlo Pro 3 Floodlight
- Can I connect an arlo pro 3 floodlight to a WiFi e...
Can I connect an arlo pro 3 floodlight to a WiFi extender?
Yes because the extender is part of your home network. There would be no reason to ever use an extender if it wasn't.
Yes. Arlo Pro 3 Floodlight can sync to your Arlo Base Station/SmartHub or directly to your home network.
So I know it will work on your home network but will it work with an extender?
Ok, thank you
