Arlo Pro 3 Floodlight missing recordings at night
  • 763 Views
rbeitter
My Arlo Pro 3 Floodlight records movement during the daytime and the photos are very clear. For some reason my floodlight stopped recording movement at night. Floodlight turns on but does not record, I’ve removed the battery and recharged. Anyone else experiencing this issue?
Screenshot(s) of your rule for the floodlight at night may be useful. I'm guessing that may be you have a setting for turning the floodlight on but not to record.
rbeitter
@rbeitter - you posted several screenshots, but not the rule for the camera.  This is found in the mode you are using.
Also, the VMB4540 is a smarthub model, not a camera.  It would be good if you can confirm the camera model.  The normal Pro 3 has a spotlight (not a full floodlight).   But often people assume that is the floodlight camera.
  • 764 Views
