Pro3 floodlight views only in black and white
  • 596 Views
jcgeorges
only shows B & W images with low sensitivity. Higher sensitivity whites out image
totally.
totally.
Are you talking about at night?  Or during the day?
If you are livestreaming at night, have you tried turning on the light?  By default it only turns on when it detects motion.
Mikey94025
Virtuoso
Virtuoso
totally.
I think attaching some sample screenshots will clarify what you're describing.  What happens if you turn off night vision?
Higher sensitivity doesn't "white out" the video - that's the function of the brightness control. Sensitivity is set in the camera settings under Default Mode Settings.
  • 597 Views
