Pro 3 floodlight in standby
  • 1038 Views
rwt75010
  • Oh My Pro 3 wireless floodlight constantly goes into standby mode, regardless of what I set in home and away. I have it set to arm, but it never does. Any ideas how to fix this?
Mikey94025
Virtuoso
Virtuoso
Do you mean your floodlight becomes disabled?  I had a problem where my floodlight of many years started doing that -- The app showed a notification of "The camera and light are disabled while charging". It was ultimately caused by a defective magnetic charging cable: see here.
rwt75010
Yes I meant disabled.  The camera works fine once I re-enable it.
BrookeN
Try to do a factory reset on the camera and see if that resolved the behavior you are seeing.
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
  • 1039 Views
